Version 2.0
A project log for 4014 LED minimodule
A cheap, small module that displays two 7-segments digits with simple multiplexing
yann-guidon-ygdesYann Guidon / YGDES 08/22/2016 at 01:192 Comments
I just updated the PCB and that's pretty neat indeed !
So it looks like the protection diodes are a "feature" that can become beneficial if it is used creatively :-)
The Eagle file is updated as well and a PCB run is started, stay tuned !
Alex wrote 08/22/2016 at 15:20 point
That is looking good! The new PCB is now it is also simple to etch the new PCB at home.
Yann Guidon / YGDES wrote 08/24/2016 at 02:52 point
Exactly !
I can't believe it's now so easy....
A new set of boards is in production now, might arrive in a month.
The only drawback I see is potentially inconsistent luminosity from segment to segment because these LEDs are not rated at such low current.
