TM4C1294 USB Host for Logitech Extreme 3D Pro
Using the microcontroller to interface with the joystick.
I think I got it right.
Create a new ccs project with no main.c
Copy the contents of the zip file into the project, overwriting any existing files.
Copy usbhhid.h into the appropriate directory
If your project has the startup_ccs.c and a tm4c1294ncpdt_ccs.c exclude the tm4c1294ncpdt_ccs.c from the build.
*The naming could be different, but if you have two startup files you will probably get three re-declarations. At any rate exclude the one that CCS generated from the build and use the one from the zip.
usbhid.h
C:\ti\TivaWare_C_Series-2.1.2.111\usblib\host
h - 24.44 kB - 08/18/2016 at 11:58
Download
usb_host_joystick.zip
I had originally mangled the byte order for the x and y, but it looks like it is fixed now. change line 15 in usb_host_joystick/include/usbhhidjoystick.c from #include "usblib/host/usbhhidjoystick.h" to #include "usbhhidjoystick.h"
x-zip-compressed - 253.34 kB - 08/17/2016 at 13:27
Download
  • Controlling an OWI arm with the joystick and microcontroller
    jlbrian708/25/2016 at 20:41 0 comments
  • Report Descriptor
    jlbrian708/17/2016 at 13:38 0 comments
    Report descriptor (packet) structure
    Byte.BitFunctionDescription
    0.7X7
    analog value X LSB
    0.6X6
    0.5X5
    0.4X4
    0.3X3
    0.2X2
    0.1X1
    0X0
    1.7Y5
    analog value Y LSB
    1.6Y4
    1.5Y3
    1.4Y2
    1.3Y1
    1.2Y0
    1.1X9
    analog value X MSB
    1X8
    2[4:7]H[1:4]hatswitch buttons
    2.3Y9
    analog value Y MSB
    2.2Y8
    2.1Y7
    2Y6
    3[0:7]Rzanalog value yaw (rotation)
    4[0:7]B[1:8]Buttons 1 to 8
    5[0:7]Tanalog throttle
    6[0:7]B[9:12]Buttons 9 to 12
    http://processors.wiki.ti.com/index.php/Stellaris_USB_Host_Joystick
  • Build
    jlbrian708/17/2016 at 11:34 0 comments
    **** Build of configuration Debug for project usb_host_joystick ****
    "C:\\ti\\ccsv6\\utils\\bin\\gmake" -k all
    'Building file: ../startup_ccs.c'
    'Invoking: ARM Compiler'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 --abi=eabi -me -O4 --opt_for_speed=5 --include_path="C:/ti/TivaWare_C_Series-2.1.2.111/examples/boards/ek-tm4c1294xl" --include_path="C:/ti/TivaWare_C_Series-2.1.2.111" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/include" --include_path="C:/Users/JBrian/Documents/workspace/usb_host/usb_host_joystick/include" --advice:power=all -g --gcc --define=ccs="ccs" --define=PART_TM4C1294NCPDT --define=TARGET_IS_TM4C129_RA0 --diag_wrap=off --display_error_number --diag_warning=225 --gen_func_subsections=on --ual --preproc_with_compile --preproc_dependency="startup_ccs.d" "../startup_ccs.c"
    "../startup_ccs.c", line 236: remark #1527-D: (ULP 2.1) Detected SW delay loop using empty loop. Recommend using a timer module instead
    "../startup_ccs.c", line 254: remark #1527-D: (ULP 2.1) Detected SW delay loop using empty loop. Recommend using a timer module instead
    "../startup_ccs.c", line 272: remark #1527-D: (ULP 2.1) Detected SW delay loop using empty loop. Recommend using a timer module instead
    'Finished building: ../startup_ccs.c'
    'Building file: ../usb_host_joystick.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 --abi=eabi -me -O4 --opt_for_speed=5 --include_path="C:/ti/TivaWare_C_Series-2.1.2.111/examples/boards/ek-tm4c1294xl" --include_path="C:/ti/TivaWare_C_Series-2.1.2.111" --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/include" --include_path="C:/Users/JBrian/Documents/workspace/usb_host/usb_host_joystick/include" --advice:power=all -g --gcc --define=ccs="ccs" --define=PART_TM4C1294NCPDT --define=TARGET_IS_TM4C129_RA0 --diag_wrap=off --display_error_number --diag_warning=225 --gen_func_subsections=on --ual --preproc_with_compile --preproc_dependency="usb_host_joystick.d" "../usb_host_joystick.c"
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/include/string.h", line 186: remark #1527-D: (ULP 2.1) Detected SW delay loop using empty loop. Recommend using a timer module instead
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/include/string.h", line 200: remark #1527-D: (ULP 2.1) Detected SW delay loop using empty loop. Recommend using a timer module instead
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/include/string.h", line 214: remark #1527-D: (ULP 2.1) Detected SW delay loop using empty loop. Recommend using a timer module instead
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/include/string.h", line 316: remark #1527-D: (ULP 2.1) Detected SW delay loop using empty loop. Recommend using a timer module instead
    "../usb_host_joystick.c", line 156: remark #1534-D: (ULP 7.1) Detected use of global variable "g_ui32NumHostClassDrivers" within one function "main". Recommend placing variable in the function locally
    "../usb_host_joystick.c", line 164: remark #1534-D: (ULP 7.1) Detected use of global variable "g_psJoystick" within one function "main". Recommend placing variable in the function locally
    "../usb_host_joystick.c", line 164: warning #552-D: variable "g_psJoystick" was set but never used
    'Finished building: ../usb_host_joystick.c'
    'Building file: C:/ti/TivaWare_C_Series-2.1.2.111/examples/boards/ek-tm4c1294xl/drivers/pinout.c'
    "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.7/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 --abi=eabi -me -O4 --opt_for_speed=5 --include_path="C:/ti/TivaWare_C_Series-2.1.2.111/examples/boards/ek-tm4c1294xl"...
  • Output
    jlbrian708/17/2016 at 11:30 0 comments
  • Created / Modified Files
    jlbrian708/17/2016 at 11:29 0 comments
    usb_host_joystick.c
    include/usbhhidjoystick.h
    TivaWare_C_Series-2.1.2.111/usblib/host/usbhhid.h
View all 5 project logs
Madhusudan Kumar wrote 10/24/2017 at 09:00 point
I am getting errors like
USBH_EVENT_HID_JS_S is undefined
USBH_EVENT_HID_JS_Rz is undefined
USBH_EVENT_HID_JS_X is undefined
Almost all these events are throwing the error to me.
drakehornbridge wrote 01/24/2017 at 15:46 point
I really like this project but seem to be having difficulties replicating your results for another device. Do you have any suggestions for me?
