Projects are always awesome when you begin the prototyping phase, but it rarely goes smoothly. The current design had too much slop around driving rod, needed another point of contact for the driving rod, slightly more robust parts, and needing better fitting hardware. But even will all these changes needing to be made, the result is definitely visible. More updates soon as the new parts have just come off the printer :)
Alex Anderson
