Just when I thought I was out...this project pulls me back in.
A project log for TP4000ZC Serial DMM Adapter
USB adapter for cheap RS232 DMMs that translates into a "sane" serial protocol
ted-yapoTed Yapo 08/18/2016 at 14:540 Comments
I built a second copy of the adapter for my other meter - and guess what? It didn't work. In fact, the second meter didn't work with the first adapter, either (should have checked this before). Turns out I had mis-interpreted the analysis of the interface circuit inside the meter, and come up with a bad solution to interfacing the thing with the nano. I re-worked the interface so it's a lot more robust with both meters, and updated all the project text and images (this took much longer than the actual fix).
Anyway, it works well with both meters now, and the electrical interface makes a little more sense.
So much for my hack-a-day rate. I'm down to a hack-every-two-days now. :-(
