I use the following program to print the text from Edgar Allan Poe's The Raven from RAM to the TTY output, it loops until system reset.
$0000 loads the hex number #1000 into register R0 $0002 loads the hex number #0001 into register R1 $0004 load value of register R0 into register R3 $0005 output R3 to I/O channel 0 (TTY) $0006 into R0 add R1 $0007 jump back to address $0004
Assembled program:
0000 1400 1000 LDW R0, #1000 0002 1410 0001 LDW R1, #0001 0004 1230 ---- LDW R3, $R0 0005 4230 ---- PUT R3, @0 0006 8001 ---- ADD R0, R1 0007 7000 0004 JMP $0004 0009 0000 ---- HLT
'The Raven' text encoded from address $1000 onwards (below is an example):
1000 0045 0064 0067 0061 0072 0020 0041 006C
1008 006C 0061 006E 0020 0050 006F 0065 000D
...etc...
Martian
