Another Test Program - Graphics
05/13/2020 at 15:15 • 0 commentsOn Logisim:
On virtual CPU:
Sample Program
05/13/2020 at 13:12 • 0 commentsI use the following program to print the text from Edgar Allan Poe's The Raven from RAM to the TTY output, it loops until system reset.
$0000 loads the hex number #1000 into register R0 $0002 loads the hex number #0001 into register R1 $0004 load value of register R0 into register R3 $0005 output R3 to I/O channel 0 (TTY) $0006 into R0 add R1 $0007 jump back to address $0004
Assembled program:
0000 1400 1000 LDW R0, #1000 0002 1410 0001 LDW R1, #0001 0004 1230 ---- LDW R3, $R0 0005 4230 ---- PUT R3, @0 0006 8001 ---- ADD R0, R1 0007 7000 0004 JMP $0004 0009 0000 ---- HLT
'The Raven' text encoded from address $1000 onwards (below is an example):
1000 0045 0064 0067 0061 0072 0020 0041 006C 1008 006C 0061 006E 0020 0050 006F 0065 000D ...etc... -
CPU Instructions
05/13/2020 at 12:48 • 1 commentThe instruction decoder takes the 16-bit contents of the Instruction Register, 12-bit microcodes determine which control signals are sent out to operate the various parts of the CPU and computer.
Computer Layout
05/13/2020 at 12:36 • 0 commentsHere is an overall layout for a complete computer. The CPU is connected to selectable RAM and ROM memory, the current address and word are displayed on 7-seg LEDs. There are 16 separate I/O channels, connected are a keyboard, a TTY display and a LED matrix for simple graphics.
Some additional peripherals can be added later, a data storage device and speaker are planned.
CPU
05/13/2020 at 12:30 • 0 comments![]()
Instruction Decoder
05/13/2020 at 12:27 • 1 commentInstruction Decoder
Register File
05/13/2020 at 12:26 • 0 comments![]()
ALU
05/13/2020 at 12:25 • 0 commentsALU
CPU-16 Final Design
05/13/2020 at 12:10 • 0 commentsFirst I'd like to thank people who have contacted me, liked, followed or asked to join the project. I'd like to everyone who has given me advice and helped me learn something new.
After a hiatus, I have finalised the design for my 16-bit CPU. I had to rework it as I moved from Logisim to Logisim Evolution. I'm going to upload the diagrams, starting with the ALU, then the Register File, Instruction decoder then the actual CPU and a working computer based around it. Then I will give an example program, instruction set etc. etc.
More to follow....
CPU emulator almost complete - Apr 23, 2018
04/23/2018 at 18:53 • 0 commentsRecycled the Python code from my previous custom CPU emulators and have it mostly working, although there are some bugs to fix.
Things to do...
- Fix bugs in Emulator
- Test progs in Emulator already created in the Logisim version
- Clean-up CPU design in Logisim
- Concentrate on just writing programs for the CPU, probably over the summer.
Martian
