An oversight regarding power supply
A project log for Smart Bed Lighting
Motion activated bed lighting that only turns on between the hours of 9PM and 7AM. Lights your way automatically.
scott-clandininScott Clandinin 10/30/2016 at 07:020 Comments
I just realized recently I made a silly mistake when I designed this project. I've been so used to working with the standalone ATMega and always needing a 5V regulator. When I decided to use an Arduino Nano for this project I overlooked the fact that it already has a built-in regulator.
I was feeding 5V into a 5V on-board regulator, and since regulators always operate with a voltage drop, the voltage actually supplying the microcontroller was around 3.5-4V. Everything worked fine, but it would be more reliable at the correct 5V.
It was a quick 5 minute job to pull off the external regulator I was using and re-route the power directly to the Vin pin.
