Science Tricorder by Olympus Heavy Industries
A multi-mode scanner and data logger based on Adafruit Feather & Arduino
This is a project I've been tinkering with for a couple years now and it actually started out as a non-functional prop. Modeled after the Tricorder devices seen in Star Trek and heavily inspired by similar projects found online. The ultimate goal is to create a functioning handheld sensor platform that can analyze, store and transmit all sensor data collected by the unit.
It’s been a hell of a journey learning how to build this thing, all started when I saw prop Tricorders at Star Trek cons in the mid ‘90s as a little kid. I’d never believe that I’d have one like this if I told past me of it…
I’ll post more as things happen
Current scan data points:
  • Atmospheric:    Ambient temperature (averaged across 3 sensors), relative humidity, barometric pressure, Target Temp, GRIDeye temp (8x8 grid of IR thermal detectors)
  • Electromagnetic:    UV Index, IR intensity, RGB Color, Visible light intensity in Lux, UV intensity
  • Radiation:    Gamma/Xray detection
  • Gasses:       Carbon monoxide, Nitrogen dioxide, Ethanol, Hydrogen, Ammonia, Methane, Propane, Isobutane
  • Mechanical:    3-axis Accelerometer, 3-axis Digital Gyroscope, 3-axis Hall Effect Magnetometer
Currently, the Tricorder Version 6 is made up of the following:
This is now the 6th iteration of the Tricorder (the first was a prop build, not functioning), running v.o-10 code.
7-Zip - 1.96 MB - 08/24/2019 at 04:57
Download
OHI Science Tricorder V6 Chassis - Rev3 NOT FINAL.7z
Rough-draft for the V6 Tricorder 3d-printable chassis, a work-in-progress
7-Zip - 2.55 MB - 08/08/2019 at 02:31
Download
Tricorder Legacy Code (everything up to 4o-v9.rar
This is all of the code that I've written for the various iterations of the Tricorder over the past 2 years. Covers up to 4Ov9
RAR Archive - 79.19 kB - 06/09/2018 at 20:41
Download
OHITricorder-4O.10.7z
Updated 2018/06/04. Added functionality to Radiation scan mode and working further on UI changes.
7-Zip - 14.25 kB - 06/04/2018 at 22:50
Download
Arduino Libraries - OHI Tricorder.7z
These are all of the libraries needed to compile the tricorder's firmware.
7-Zip - 42.46 MB - 04/13/2018 at 02:27
Download
View all 6 files
  • 1 × Adafruit Feather M0 Adalogger (https://www.adafruit.com/product/2796 ) Primary microcontroller for the unit
  • 1 × Adafruit CAP1188 (https://www.adafruit.com/product/1602) Capacitive Touch controller
  • 2 × Adafruit Neopixel (https://www.adafruit.com/product/1558) Controllable tri-color LEDs, used for display and messaging
  • 1 × MPU9250 Add-Ons for Ladybug + BME280 (https://www.tindie.com/products/TleraCorp/mpu9250-add-ons-for-ladybug/ ) 9-DOF and Atmospheric sensor board
  • 1 × Generic SI1145 (https://www.amazon.com/dp/B07MY2TPNV) UV Index IR intensity sensor board
View all 15 components
  • Now in 3d, the Return!
    Queadlunn08/24/2019 at 05:14 0 comments
    Gotten a lot further along with the 3d shell, the primary parts are at least mostly done and I'm working on test-printing and fine-tuning stuff now.
    The big things left are getting the interface panels for the body and door further along. The main body panel needs cutouts for the TFT and controls, the door panel needs holes for the capacitive wire.
    The mainboard simply slides into the body and the body's under part (violet-colored in the 3d model image) fixes it in place. The desing's working pretty well so far but it does need a lot of tweaking for ease of use and ease of printing.
    Uploaded the current rev of the models as
    OHI Science Tricorder V6 Chassis - Rev5 NOT FINAL.7z.7z
  • And for the rough-draft
    Queadlunn08/08/2019 at 02:35 0 comments
    Added (really) rough-draft files for the V6 3d-printable chassis:
    "OHI Science Tricorder V6 Chassis - Rev3 NOT FINAL.7z"
  • Now in 3d!
    Queadlunn08/07/2019 at 06:15 0 comments
    After quite a while I've started to work on the next version of the Tricorder! I've had the hardware partially built for a while now but I'm starting to get the casing worked out in 3d so I (and anyone that wants to) can print it. It's going to take a lot of work since it's my first 3d design like this. Once I test it out and can make some changes I'll upload an STL and the original 123dx files.
  • More Progress, building Version 6
    Queadlunn01/15/2019 at 05:22 0 comments
    After a long lag I'm working on the hardware for the next version of the Tricorder!
    It's not a huge change from the Version 5 to Version 6, more of cleaning up the current design that the Version 5 ended up with. The soldering work is about half done right now, I still need to finish up the sensor array, additional sensors and the door assembly.
    The current Version 5 will have some of it's sensors moved to the V.6 (the GridEYE, 9-DOF/ATM, UV sensors) and everything else will be the same sensors in smaller breakout boards.
    Changes with the Version 6:
    • Slightly re-designed, a bit wider and shorter to allow a touch more room
    • Different sensors for:
    •      Gas sensing, got the newer version of the sensor board
    •      LUX, IR sensors replaced with same IC but smaller breakout board
    • This Feather M0 has a Packet Radio for if I make any hand scanners in the future, still unsure of that
    Ultimately I want to keep the older version working, likely remaking the casing so I can fit bulkier sensors into it (like the shape of the TNG Medical Tricorder). Since both will be using the same Feather M0 boards I also want to write one firmware that will work on both units if possible.
    Right now I'm focusing on the hardware and will resume on the code afterwords.
  • Code updated to v10, a bit of work done...
    Queadlunn06/04/2018 at 22:58 0 comments
    Small update- Got a bit of work done on the code today, expanded the Radiation scan mode's functionality. Now it shows avg pulses/second, avg pulse strength (in uSv/h) along with the last pulse detected.
    Part of this was making a timer based off of the RTC to count how long the scan mode has been on, this could be useful in other modes later on as well.
    I also got a bit further on in building a framework to allow a more interactive UI. The ultimate goal is to have the ALT button switch the button pad's functionality to that of a D-PAD along with Confirm, Cancel and Back. This'll give me a lot more to work with, like highlighting scan elements or using a menu structure. A lot of work to do on this however...
    The updated code has been attached to the project, v10.
  • Bringing it up-to-speed
    Queadlunn04/13/2018 at 02:17 0 comments
    In the past year the external appearance of the unit hasn’t changed much, it’s all been internal hardware and code changes. As the photos show, the mainboard is getting to be a rat’s-nest of wiring with all of the changes and adaptation that I’ve done. The code, actually, is a lot cleaner than when I was at the same point last year. It’s able to do a fair bit more but isn’t using much more of the Arduino’s (Adafruit Feather M0 Adalogger) memory (still hovering around 30% at this point).
    The sensors in the unit haven’t changed a huge deal, I’ve gotten them to work a bit better though and have even been able to adapt the libraries for the Gas sensor to work with the M0 controller (more brute-force really but it works). The total sensor list is posted below.
    At the moment I’ve gotten 2 replacement sensor part. One to replace the Grideye sensor so it’s smaller (I can’t do surface-mount soldering yet) and one to replace both the atmospheric sensor board and the 9-depth-of-field sensor board that captures movement. The second will combine both the ATM and 9-DOF into one very small package, saving on the limited internal space within the Tricorder.
    There are a few things I want to add into the unit so far: GPS (for both location data and accurate clock updates), Haptics (feedback from button presses, sensor alarms), and finding a replacement and higher quality display are my biggest. The largest hurtle right now is getting the code solid, using the display to give clear and accurate readouts of the sensor data, and eventually rebuilding the mainboard and chassis. The chassis’ ABS/aluminum/polycarbonate construction is rock-solid (it’s been hanging out in my camera bag for the last year) but I want to clean it up since the off-square lines in the current one bother me a bit.
    My big inspiration for the project has been the Open Source Science Tricorder by Peter Jansen. It’s an incredible project and I have major respect to the creator.
View all 6 project logs
josh034 wrote 3 days ago point
Thank you for responding so quickly. Again, sorry for so many questions. But the assembly guide would answer these. I should have waited for that. You have been very gracious in your replies. I will ask this, as it won't be in the guide. Do you plan on selling these in kit form, or anything like that? Now I will have patience and await the assembly guide. 🙂
Queadlunn wrote 3 days ago point
Not at this time. Maybe in the future, when I have my own PCBs designed but even then they'll take a good amount of soldering work to get operational.
I have a three questions, if you don't mind. In the picture of an up close view of the screen with the system in ATM Mode, what is Target A and D? Is there a B and C somewhere? The other question is, is there anything under the keyboard, other that wires?  I couldn't decide, from looking at all the pictures, but I am guessing not. The last is about the carbon fiber in the 3d printing. What are the qualities of that particular material? Is it wear resistant, holds up to impact, etc? Sorry to have so many questions. But I really want one of these. And I'm trying to understand it all, but I have zero skills in electronics.
ATM Target sensor A is an Average of the center 4 pixels of the GridEye sensor (an 8x8 thermal IR sensor), sensor D is the MLX90614, a Direct measurement.
Under the key panel is the Adafruit CAP1188, the wiring going from the Door assy to the main body is 2-wire 12c, an interrupt for the capacitive controller, +v and Gnd.
Carbon fiber PLA is, I'm assuming, the strongest material that my printer can work with in its current state. If I could print in ABS, Polycarbonate or other more resilient materials I probably would have gone with those.
I'll be doing another iterative chassis print and I think it's close to complete for this version. At that time I'll probobly do a write-up/guide covering assembly. The chassis is designed to be easy to assemble and doesn't require specific boards aside from the mainboard being a specific size and the capacitive breakout PCB (this could be changed too, with a bit of work). It'll likely require soldering work no matter what but the actual internals could be simplified a fair amount, at that point it'd just take minor soldering and changing the code.
josh034 wrote 6 days ago point
So it won't be that heavy. That would be easy to skip into a backpack or pocket if needed.
If I remember, you said somewhere you were going to finalize the printed material in carbon fiber?
Queadlunn wrote 6 days ago point
I'm going to print the final chassis assembly for the v6 unit with carbon fiber PETG or PLA, something like this:
https://www.matterhackers.com/store/l/3dxtech-carbonx-petg-3mm/sk/MKJ2V47R
I haven't used carbon fiber-filled print filament before but it should be fairly easy to tune my printer to work with it, I've already got an upgraded hotend and hardened nozzle installed.
josh034 wrote 09/12/2019 at 15:48 point
Understood. I knew from looking at the pictures space is at a premium. And speaking for myself. I like the current clam shell style. I would use it as an EDC device, so the clan she'll would be protective without an extra case. That does bring up a question. What is the weight of the two models you have: the green metal one vs the 3D printed one?
Queadlunn wrote 7 days ago point
The v5 Aluminum and ABS chassis one is 272g.
The v6 PLA-printed chassis is 190g but still missing some internals. This will be printed with different filament for the final build so maybe around 220g?
josh034 wrote 09/12/2019 at 02:06 point
Would you need to make major changes to  the design to accommodate the other two? And would you need switch to a D-pad style of controller? I ask that because I'm not sure where you would add another button to the current design.
Queadlunn wrote 09/12/2019 at 06:22 point
Physical space is always an issue in this design for the actual sensors. For the controls I do plan on moving away from the simple press-of-a-button mode switching to some semblance of a button-controlled UI but that's well down the line right now.
josh034 wrote 09/11/2019 at 17:38 point
Would it be possible to use one of the sensors for lightening detection?
Queadlunn wrote 09/11/2019 at 17:53 point
It's one that's been on the list of 'possible additions' I've had for a while now:
Lightning Flex Module (RF) - https://www.tindie.com/products/Fyberlabs/lightning-flex-module/
Magnetic Imaging Tile - 8x8 - https://www.sparkfun.com/products/14652
Adafruit Ultimate GPS Breakout - https://www.adafruit.com/product/746
Adafruit SGP30 Air Quality Sensor - https://www.adafruit.com/product/3709
The magnetic imaging tile is likely too much for this project in processing needs and physical size, and the GPS would likely be too large. The other two might work out later on though.
josh034 wrote 08/29/2019 at 14:57 point
Thank you for your answers. Sorry for all the questions.
Queadlunn wrote 08/29/2019 at 18:46 point
No worries, I'm glad to answer questions about the project!
josh034 wrote 08/29/2019 at 14:05 point
I like your design.  I am anxious to see your design come to completion.
Is it possible to upgrade the sensors and software without starting over from the square one?
Queadlunn wrote 08/29/2019 at 14:48 point
Upgrading should be fairly easy once a unit is completed. Since I'm currently designing the electronics around pre-made breakout boards for most components all that's needed to change/upgrade a sensor is to wire it in and update the Arduino code with what the new components need to do. Upgrading the Adafruit Feather also should be pretty easy as long as the microcontroller itself is the same, otherwise the pins would need to be updated and code changed to work properly. Some core components like the i2c multiplexer and clock will (eventually) be soldered to the mainboard whenever I can get my own PCBs designed.
josh034 wrote 08/29/2019 at 14:00 point
Ok. It sounds like the 3d prints will be pretty good too. Like I said, for myself, this would be an EDC device. So durability would be important. But it sounds like that won't be too bad. And if the circuit board stayed in place from an approximate 1 meter drop, then that is half the battle.
josh034 wrote 08/29/2019 at 00:39 point
I was thinking of this as an EDC item. So water resistance, or lack thereof, would be important. Another question is durability? Have you used one of your builds enough to know if that would be an issue?
Queadlunn wrote 08/29/2019 at 04:02 point
The older aluminum/abs casing is pretty sturdy, it's been carried around for a couple years in the bottom of bags and dropped a meter or so a number of times and seems pretty resilient.
The 3d-printed casing I'm working on I don't really know yet. I'm doing my best to design it for strength (and will print it with carbon fiber+PLA for the final version) but can't test it yet.
josh034 wrote 08/28/2019 at 21:15 point
Have you done anything to make the device water resistant?
Queadlunn wrote 08/28/2019 at 21:52 point
Not yet, I could probably seal off most of the body and door assemblies but many of the sensors need unobstructed exterior access (or to figure out non-impeding glass shields). For now I'm going to harden the casing to make it fairly resilient but maybe at a later point I might look at sealing the design up.
Tim Rightnour wrote 08/16/2019 at 15:48 point
I like the idea of averaging 3 temperature sensors.  How does that play out in practice?  Do they diverge alot?
Queadlunn wrote 08/24/2019 at 05:17 point
It's usually pretty close to accurate from what I can tell, though letting the tricorder acclimatize for a bit is the best way for it's internal temp sensors to get an accurate average. When I need a quick check I usually use the non-contact IR temp sensor and point to something metal at about hip-level.
Daemon informatica wrote 08/07/2019 at 13:06 point
Did you know there is (or used to be) a project where people are challenged to build medical tricorders to detect / diagnose symptoms and deceases? ^_^ Quite a monetary incentive too, if I recall correctly..
Nice work. I've been messing around with ideas to build one myself, but mostly because I once got a medical tricorder prop somewhere in the past, and been meaning to extend it with actual hardware.
Ken Yap wrote 08/07/2019 at 15:10 point
As in "He's dead Jim"? 😉
Queadlunn wrote 08/07/2019 at 17:00 point
I would like to build a medical tricorder at some point, but I don't trust my skills enough to use something for critical needs like anything medical, sadly...
Ken Yap wrote 08/07/2019 at 04:23 point
Hahaha cute 👍. You also need to make one of those cylindrical flashers used by Bones for body scans. That one doesn't need to do anything but flash and make a woo woo sound.
Queadlunn wrote 08/12/2019 at 16:53 point
I did make a hand scanner at one point, just some neopixels that were triggered by a cheap magnetometer:
https://ohicosplay.tumblr.com/post/161560143234/queadlunn-heres-something-i-put-together-today
TheotherMike wrote 02/11/2019 at 16:33 point
Not bad! Unfortunately I was never able to finish my own one. I´m still not sure about the basic strategy how to build it. You´re using a µC with on board radio, that´s useful in the long term I think. I also thought of using only limited amount of sensors within the main unit which might give long runtime, small size and weight. Using LoRa etc. one could shift all heavy duty sensors out to accessorie units...
TheotherMike wrote 02/11/2019 at 12:09 point
Hah, cool Project ! I found it because of your comment on another tricorder build... ;-)
You really have a hell of a lot of sensors in tis package.
How Long can it rum from batteries?
Queadlunn wrote 02/11/2019 at 16:13 point
The current version will run for about 3 hours on the 500mAh battery. The newer version will hopefully have a 700 mAh battery though which should make it run a bit longer.
