(continuing from the main description...) The degraded 1 PPS edge is a problem for really precise applications, but I needed only be close to UTC as I use a second 1 PPS source to sync to the correct second and set timing for the rest of my system. That is, I take time from the Linux system and set it on an embedded system that is disciplined by a high-quality 1 PPS.
ksk
Tim
Bob Anderson
Tommy Liao
Voja Antonic
