Schematic!
A project log for LiFePO4wered/Solar1
A complete LiFePO4 based solar power supply for IoT devices
patrick-van-oosterwijckPatrick Van Oosterwijck 11/17/2016 at 19:010 Comments
I've added a PDF of the schematic! At this point, the main charging part is know to work, but not thoroughly tested over the full voltage and temperature range. The over and under temperature protection has not been tested either, nor has the heater.
But it might be useful to someone to get an idea. :)
