1Step 1
This is just a summary of building a glussbot:
- Get at least 6 Actuonix Feedback actuators: http://www.actuonix.com/L16_Linear_Actuators_p/l16-p.htm for about $80 each.
- Purchase the custom motor controller shield: https://oshpark.com/shared_projects/fijpozoB
- Solder together the shield with all components:
- 3 Pololu dual channel motor driver breakout boards: https://www.pololu.com/product/713
- A sparkfun BlueSmirf Gold BlueTooth module: https://www.sparkfun.com/products/12582
- Lots of headers to make a proper shield
- Mount the shield on an Arduino Mega
- Use a 3D printer printer the mountable Mega-and-battery-pack cases: https://github.com/PubInv/gluss/blob/master/MegaAndShieldEnclosure/combined_enclosure.scad, https://github.com/PubInv/gluss/blob/master/MegaAndShieldEnclosure/combined_enclosure.stl
- 3D printer the lid
- Choose the Turret Joint or Magnetic joint system
- 3D print all of the connectors (this is constantly evolving, so I am hesitant to fully document it, but all files are here: https://github.com/PubInv/turret-joint/tree/master/STLs)
- Connect the system together
- Load the Arduino drives onto each Arduino Mega: https://github.com/PubInv/gluss/blob/master/GlussPCBv0.1/GlussPCBv0.1.ino
- Use (and probably tweak) the emacs electric lisp program to issue commands via BlueTooth to the system: https://github.com/PubInv/gluss/blob/master/emacs-ctl.el
- Develop and share new Glussbot gaits and applications.
Robert L. Read
