Battery testing... and failing
A project log for ESP8266 MQTT Infrared AirCon Control
An amateur build of a monitoring and control system for the aircon in my baby's room, using an ESP8266, IR Led, JSON and MQTT protocol.
shoeboxShoebox 12/02/2017 at 10:080 Comments
This weekend, I decided to test the battery life of my prototypes.
The program is currently processing for 30 seconds, then sleeping for 1 minute
Those times are fairly disappointing. I don't want to be changing batteries every day.
I might go down the static IP route to speed up the connection, and then play with the awake/sleep ratio. I should be able to decrease awake time, and increase sleep time.
