Performance Evaluation of the OpenLD
A project log for OpenLD: Lucid Dreaming Research Platform
An open source platform to help induce and explore the realm of Lucid Dreaming for Research and Personal Well-being
jae-choiJae Choi 09/15/2016 at 17:290 Comments
Root Mean Squared (RMS) Noise of OpenLD
Here is the plot of the noise recorded by the OpenLD hardware. In order to measure this noise, the electrodes were all shorted out by connecting the positive channel inputs to SRB1 and the BIAS pin. For the ADS1299 configuration, the PGA gain is set to 24 and 4 channels were powered on.
The datasheet indicates that the RMS Error (equivalent to the standard deviation) of the signals (at 24x gain and 250SPS) are approximately 0.14uV (pg. 7; Table 4). If you look at the diagram above, the RMS values of the signals recorded by the OpenLD is also around 0.14uV. Brilliant.
