Detection testing of Owlie at different distances.
A project log for Blind guiding device (Owlie)
Owlie is a blind guiding device which provides hand free option to a stick and is more user friendly compared to other similar devices.
debbie-leungDebbie Leung 09/18/2016 at 20:380 Comments
This video contains testing of Owlie at different distances. Owlie beeps from the buzzer and vibrates from the pager motor only once between 150 cm and 100cm from an object to let the user be aware of an object in that distance. As the object gets closer between 100cm and 30 cm, it beeps and vibrates more frequently about 5 times. Then when it gets too close less than 30 cm, it keeps beeping and vibrating until the user moves away from the object. Here is the link to the video clip.Testing of Owlie at different distances
