Remote firework launcher
Set fireworks off with ether a timer or by TV remote
I've always wanted a way to safely set off firework so I decided to build one. The brains are a arduino which controls a 12v relay which intern controls the car lighter. Can be triggered with the button to start the timer or with a TV remote control from a safe distance
s32243816 wrote 04/15/2023 at 13:02 point
Download our Safety Booklet and watch our Safety Videos for lots of tips and tricks. Also, you can download this helpful guide from WorkSafe Tasmania's website How to use fireworks safely on Cracker Night. to buy click on shop fireworks.
mhdeomampo wrote 07/02/2014 at 04:57 point
Can you please help me in overclocking of raspberry pi for ASUS Xtion Pro Live. Thank you!!!
gmwatbot wrote 03/09/2014 at 22:05 point
I like!!
Have you considered using say a 10ohm resistor as an electronic match? E.g. http://www.bigclive.com/ignite.htm
Works well, add a pin board to trigger multiple fireworks.
Cheers
Ian
facelessloser wrote 07/04/2014 at 13:18 point
That's sounds like a good alturnatve, thanks for the tip.
