yet another version of my handheld BASIC system in a GameGear case
Hi, Here is my current BASIC Keywords set:
AND,OR, NOT,MOD
PRINT -----------------------> ADDED <?> shortcut
CLS
LIST, LLIST ,RUN
GOTO,GOSUB,RETURN,
REM, ------------------------> ADDED <'> shortcut
STOP,CONT,PAUSE
INPUT, INKEY$ // INKEY$ : non blocking key listening ....
IF,THEN
FOR,TO,STEP,NEXT
VAL()
INT(),RND() // int(1.5) -> rounds to 1 // rnd -> returns between 0.00 & 1.00
STR$() // STR$(1) => "1" (allows string concat)
LEN(), // LEN("abc") => 3
RIGHT$(),MID$(),LEFT$(),
POSITION,LOCATE <COL>,<ROW>
LET,DIM,
MEM --> function that return free ammount of RAM
SAVE,LOAD,NEW, CHAIN, DELETE
DIR, ----------------------> ADDED optional extension filter ex: DIR ".BAS"
DIRARRAY ------------------> Stores FS list in "DIR$" ARRAY VARIABLE
DIRM ----------------------> show FS content for MCU#2
MUTE (toggle mute buzzer)
BEEP 100,2 : 1-48 produces some notes, direct freq. otherwise, beeps for 2*50msec
PLAY "ABC#" : play some notes of OCTAVE_4
PLAYT5K & PLAYT53 : to play audio (beep) files
DRAWBPP : display a 1bpp (B/W) picture to builtin screen
DRAWPCT : display a 64K colors picture
DRAWSPRT : draw a sprite (portion of a .PCT image file)
CIRCLE x,y,r : draw a circle
LINE x,y,x2,y2 : draw a line
PSET x,y : switch ON a pixel
PRESET x,y : switch OFF a pixel
RECT x,y,w,h,c,m : c : 0,1,2,3 (black,white,gray, darkGray) // m : 0,1 (draw,fill)
TRIANGLE x,y,x,y,x,y,c,m : as same as RECT but draws a triangle
BLITT x : 0 stop blitt / 1 trigger blitt / 2 auto blitt (default mode)
SCREEN 0/1/2 : switch resolution (128x64, 160x128, 320x240)
(TEXT 0/1 -> change text overlay mode)
BTN(x) : function get button state
LED [1..3], {0,1} : switch on/off a LED
( CONSOLE <out>,<in>,<gfx> : set I/O + GFX main devices )
( ECHO {0;1} : enable/disable console output )
DELAY x : wait x msec
SECS : function that returns nb of seconds elapsed since boot
MILLIS : function that returns nb of milli-seconds elapsed since boot
UPPER$(str) : function that return UPPERCASE of str
STRING$(nbTimes, chr) : function that returns repeating string of nbTimes * CHR$(chr)
CHR$( chr ) : function that return a char of given ASCII code
SPACE$(nbTimes) : function that returns repeating string of nbTimes * CHR$(32)
ASC( str ) : returns ascii code of 1st char of str
INSTR( str, toFind ) : returns index of 'toFind' in 'str' (else 0)
ABS(x) : return absolute value of number
COS(x) : return cos( x in radians)
SIN(x) : return sin( x in radians)
SQRT(x) : return square-root of x
POW(x,y) : return x pow y
MIN(x,y) : guess
MAX(x,y) : guess ...
EXEC "<extCmd>", "[<extArg>]" : to launch an extended command
DO "? 3.14" : ~ as eval() in JS, interprets & launch a String expr.
DATAF "file", "SZ", "A$", "B" -> feeds A$ & B arrays w/ a PSEUDO CSV file content (ex: file.BAD) of a length of SZ
(DATAU "url?", "SZ", "A$", "B" -> will do as same but with an URL)
(COPY "/TOTO.PCT" -> copy an asset to MCU#2 )
BYE : to reset the MCU
HALT : to halt the MCU & optional connected RPI
I used 2x ESP32 (instead of only 1 in #Xts-uBASIC Pocket V2 ) because I needed hudge RAM to correctly manage the 320x240px Screen ops. (& ESP32 is relatively cheap & fast) so there is an UART Bridge between BOTH MCUs in order to send commands from #1 (BASIC+BEEP+BTNs+WIFI) & #2 (SCREEN + MP3Player) Then the SX1509 boards allows me to read all buttons to #1...
Hi, today I'm starting to write a little RPG demo (not a real game @ this time).
Just for the experiment & detect lags (& try to fix those)
I found this very good tutorial about case & buttons reusing...
Then I decided to try by myself.
Then I connected all buttons to a Sparkfun SX1509 I2C I/O expander.
Hi, today I mounted the 2MCUs together...
It now looks like this :
From bottom to top : we have the 2x ESP32, the GPIO expander at center, then the 320x240px TFT w/ legacy GameGear controls PCB on sides.
a small overview :
buttons are responding & bridged screen works !
Hi, last week : I added the MP3 Module (DFPlayer MINI) & wired 2x MCUs USBs + added a LED @ same place than original one.
So we have the MP3Module on left side (linked to #2 MCU), BUZZER (linked to MCU#1) on right side & 2 USBs to control BOTH MCUs (via ArduinoIDE) + a micro female USB to power the whole system (@top)
So it can now play BEEPs & MP3 Tracks !
