gear_generatorKSK 3.scadModified from design by Leemon Baird, 2011, Leemon@Leemon.com, http://www.thingiverse.com/thing:5505scad - 16.19 kB - 11/03/2019 at 23:29 |
scad - 3.24 kB - 11/03/2019 at 23:26 |
XYMotorMounts_v06.scadUpdated previous version to include hall sensor mounts and license.Mechanical stage motor mount for OMAX Microscope 40x-2500x. This body style http://www.ebay.ca/itm/OMAX-40X-2500X-Trinocular-Lab-Compound-LED-Microscope-14MP-Camera-Carrying-Case-/121661096315?hash=item1c5391017b:g:htoAAOSweW5VY4lb. However, may be able to modify for other bodies. scad - 5.00 kB - 07/08/2017 at 18:24 |
28BYJ_48.scadA model of the 28BYJ_48 geared stepper motor. Useful for creating mounts and making sure that your mount matches the motor. For example, I import this model and have an option to display it "in place" or slightly offset from the mount I am designing...scad - 3.65 kB - 07/08/2017 at 17:32 |
28BYJ_48_Mount.scadA simple block mount for the 28BYJ_48 motor.scad - 1.59 kB - 07/08/2017 at 17:31 |
MotorControllerCase.scadCase for ULN2003 breakout boards.scad - 4.59 kB - 10/31/2016 at 04:51 |
RAMPSCase_r2_fixed.scadModified RAMPS case from http://www.thingiverse.com/thing:10827scad - 11.87 kB - 10/31/2016 at 04:44 |
MicroscopeControl_v01_schem.jpgSchematic. The ring encoder breakout board has been retired by SparkFun. The UL2003 is really an LT Technology breakout board, which the housing was designed to hold, but you can mod the design for other popular form-factors.JPEG Image - 1.12 MB - 10/31/2016 at 04:10 |
