close-circle
Teensy E-Paper Adapter Board
The Simplest Way To Start Playing With A Fascinating New Low-Power Screen!
close
Buy me: https://www.crowdsupply.com/soniktech/e-paper-shield-kit
Library and examples: https://github.com/jarek319/EPD215
E-Paper is not a simple display to drive. With manual temperature compensation, onboard power regulation requiring external capacitors, and setting up a step-up circuit, there are many factors to consider when working with this display, with the large benefit of not requiring any power to maintain its image once written.
I have created the simplest possible circuit necessary to drive the Pervasive Displays E2215CS062 , available from your favorite distributor. Certain parts from the reference design were substituted with US-available equivalents with assistance from the Pervasive Displays engineering team.
This is just a jumping off point :) A more thorough library is in the works, but feel free to grab t
The necessary schematic, board files, and test code can be found below. The entire design has been validated, and is set up for production using OSHPark's PCB service, with parts all available from Digikey.
The board was made using entirely 0805 passives to make hand-soldering possible. The connector can be attaching using the "flood-and-wick" technique ( use plenty of flux! ).
x-zip-compressed - 17.14 kB - 11/04/2016 at 18:18
download-circle
Download
plain - 2.04 kB - 09/10/2016 at 22:16
download-circle
Download
ino - 323.00 bytes - 08/31/2016 at 00:51
download-circle
Download
h - 577.00 bytes - 08/31/2016 at 00:51
download-circle
Download
h - 26.47 kB - 08/31/2016 at 00:51
download-circle
Download
View all 9 files
  • 1 × Teensy 3.2
  • 1 × Pervasive Displays E2215CS062
  • 1 × E-Paper Adapter Board PCB
  • 1 × Assorted Components From E-Paper Reference Circuit
View all 4 project logs
oshpark wrote 02/10/2017 at 06:16 point
@jarek319 is there an EAGLE .lbr file with the Hirose connector?  I'm trying to do a similar design in KiCad and SnapEDA can convert from EAGLE to Kicad if I upload at .lbr.
Thanks!
Drew
Ariane Nazemi wrote 11/11/2016 at 07:42 point
Excellent project! Any plans on creating a way to display bitmap images on the display? I believe one other display company uses XBM files?
jarek319 wrote 11/11/2016 at 14:44 point
I've used LCDAssistant to convert BMP to code and have had success that way. I wrote my own mini-library for rendering bitmaps and that works fine too, but now I'm looking at integrating this into Adafruit's GFX library so I can leverage their existing BMP rendering code and all the other drawing functions.
Ariane Nazemi wrote 11/11/2016 at 22:36 point
I see. And do you know if it's possible to perform partial updates with this display? That would help tremendously for animations and such.
jarek319 wrote 11/11/2016 at 23:32 point
It's possible, I'm just not allowed to release the code under NDA :( hopefully if enough people support this open-source project, manufacturers will be more willing to part with their LookUp Tables!
alan_r_cam wrote 11/02/2016 at 12:01 point
I have several Teensy boards, including the latest 3.6 which runs on 3.3V -
My most common use for the Teensy is driving mechanical keyboards. Adding a display to a keyboard is appealing, but  I'd want:
1 - A bigger display [in dimensions and resolution], and
2 - A slimmer [low profile] layout.
So:
Does this run on a V3.6 [3.3V] Teensy?
Can I use the adapter with a different [larger] screen?
Can the adapter be connected beside a Teensy, instead of on top?
jarek319 wrote 11/02/2016 at 14:14 point
Yes, the E-paper Adapter does support the newer Teensy. I am writing an update and will post it to the CrowdSupply page soon.
I have not tested with a larger screen, but the driving circuits for the larger screens seem very similar to the circuit I'm using right now, but with different values for the capacitors and resistors. If this project gets funded, I'll take that as a sign that there is enough interest to look into bigger and more expensive screens :)
The pre-soldered adapter has female headers which accept standard hook-up wire, and the unsoldered version can be placed anywhere and have wires soldered to it that run back to your target microcontroller. In the gallery for this project you can see one example where I soldered male pins to the epaper shield and plugged it into a breadboard.
Sean Hodgins wrote 09/10/2016 at 23:01 point
Great project. There are so many uses for displays like this, I want them to gain more popularity so there are more options. Good work, I will probably make a variation of your board.
jarek319 wrote 09/10/2016 at 23:23 point
Thanks for the kind words :) Add in a solar cell, a battery, and an aggressive power management strategy, and you've got a perfect platform for extremely-low refresh rate dashboards and info displays: https://hackaday.io/project/10000/log/43672-solar-powered-and-ready-to-last-forever
oshpark wrote 09/04/2016 at 17:47 point
Hi @jarek319, is the resistor actually 2.2Ohm?  That seemed like a low value, so I wanted to double check if it was 2.2KOhm.
jarek319 wrote 09/05/2016 at 22:08 point
yup, it's a 2.2Ohm resistor. It's likely used as some reference by the epaper's onboard regulator?
oshpark wrote 09/06/2016 at 05:55 point
ok, thanks!
K.C. Lee wrote 09/05/2016 at 23:47 point
Inductor current feedback for the current-mode boost supply.  It is used to generate the ramp for the PWM signal.
thanks for the insight!
[deleted]
jarek319 wrote 08/30/2016 at 13:27 point
First I got the reference schematic from the datasheet for the display, and I redrew the schematic in Eagle. Then I created a board from the schematic using Eagle's Board Editor, and then I sent the Board file to OSHPark for fabrication. When it came back in I soldered the components to the board and wrote a quick test program :)
qquuiinn wrote 08/29/2016 at 22:52 point
Can you drive smaller displays with this driver board without having to tweak the values of the passives?
jarek319 wrote 08/30/2016 at 01:15 point
I would double check the datasheet of the display you want to use. I got the values for the passives from that specific display's reference schematic, and there should be one in the datasheet/online/from the manufacturer.
pieterkockx wrote 08/29/2016 at 05:13 point
Are these difficulties also the reason you don't see e-readers with a large display?
jarek319 wrote 08/29/2016 at 13:01 point
I haven't played with larger ones yet, but that's because of cost... these things get a little pricey at larger sizes...
pieterkockx wrote 08/29/2016 at 13:23 point
This article is interesting too:
http://essentialscrap.com/eink/software.html
Perhaps it's possible to drive multiple displays using a shared framebuffer?
Radomir Dopieralski wrote 08/29/2016 at 15:27 point
you can actually get kindle displays relatively cheap -- possibly because of their popularity
drojf wrote 08/26/2016 at 14:28 point
A couple years ago I was interested in e-paper displays, but it was too expensive to buy the dev boards/displays for it and too much effort to work out how to drive them without one...thanks for this project, I'll definitely look into it if I have the time.
It would be nice if you uploaded a PDF or image version of the schematic, so it can be viewed without Eagle (I use Kicad).
The e-paper display is available from digikey at $16 USD, qty 1: http://www.digikey.com/product-detail/en/pervasive-displays/E2215CS062/E2215CS062-ND/5975949
jarek319 wrote 08/26/2016 at 16:02 point
There is a image version of the schematic in the gallery, send me a msg if you can't make out some of the values and I'll upload a PDF too :)
drojf wrote 08/27/2016 at 00:53 point
ah sorry, I assumed the hackaday thumbnail images (which are cropped) represent the gallery images, but the gallery images are clearly full size and not cropped. There is even a "view full size" button on the bottom right which I have never seen before, and it shows the original image (which is huge!). Thanks!
jarek319 wrote 08/27/2016 at 01:18 point
no problem, good luck! feel free to message :)
oshpark wrote 08/26/2016 at 13:22 point
Thanks, this is awesome!
