Assembling the Micro-Linear Actuator
A project log for TNS 1i
The idea is to create an accesible prosthetic hand that is commercially available in Colombia and doesn't use the classic string system.
Giovanni LealGiovanni Leal 09/09/2016 at 22:401 Comment
Browsing Hackday we found out a pretty cool project about a 3D-printed joint from Tim Wilkinson. You should check out his project looks really elaborated and with a million of applications. https://hackaday.io/project/13398-custom-articulated-joint
He asked us if we could make it clearer how ours works so we made this video.
Tim Wilkinson wrote 09/11/2016 at 04:28 point
Thanks for sharing this - much appreciated.
