Assembling the Micro-Linear Actuator
A project log for TNS 1i
The idea is to create an accesible prosthetic hand that is commercially available in Colombia and doesn't use the classic string system.
giovanni-lealGiovanni Leal 09/09/2016 at 22:401 Comment
Browsing Hackday we found out a pretty cool project about a 3D-printed joint from Tim Wilkinson. You should check out his project looks really elaborated and with a million of applications. https://hackaday.io/project/13398-custom-articulated-joint
He asked us if we could make it clearer how ours works so we made this video.
Tim Wilkinson wrote 09/11/2016 at 04:28 point
Thanks for sharing this - much appreciated.
