Pin arrangement problem for Arduino IDE programming...
A project log for ULTRA ZERO, a successor of SDuino ZERO
This is Atmel SMART (ARM Cortex M0+) based board, a successor of SDuino Zero
kodera2tkodera2t 11/10/2016 at 08:100 Comments
I found errata between Arduino IDE's pin definition and on-board silk indication on ULTRA Zero.
The mis-arrangement are found between D0 to D4 and details is shown in the following image.
This difference can be aligned to "as written on board" if you have a chance to re-write firmware by Arduino.org's Arduino M0 (But it is not convenient since not main-stream so far..) Sorry inconvenient but please refer this image for your programming and prototyping.
Thank you,
