Understanding the hoverboard
A project log for OpenChair
Make your chair YOUR chair
alvaro-ferrn-cifuentesAlvaro Ferrán Cifuentes 08/31/2016 at 22:081 Comment
First things first, disassembly time! In the picture below we can see the different components making up the hoverboard. We can see two gyro boards, one main board and the battery.
Each gyro board contains a Cortex-M3 processor calculating its orientation from an MPU-6050 accelerometer/gyro sensor and sending it over UART to the main board, which is responsible for both driving the motors and charging the battery.
Thanks to Drew Dibble's work we know that the UART lines run at 26315baud, with 1 stop bit, no parity and LSB-first. In the pictures below we see the serial bus and the IR sensors used to check if the user is standing on the board, which we will spoof with a bit of tape.
Using a logic analyzer we find, as Drew explained, that the instructions follow a pattern of six commands: 0x100, 0x0aa, 0x0bb, 0x0aa, 0x0bb, 0x055. The first command marks the start of the instruction, and the last is 0x055 if both IR sensors are blocked.
We captured data at various inclination angles in both directions to find out the values of the middle bytes. The table below shows the data being sent by the board when increasing the angle. For example, if the board is tilted a few degrees forwards, it sends the sequence 0x100, 0x053, 0x000, 0x053, 0x000, 0x055, which can be seen as 0053h or 83d.
Forwards (hex) Forwards (dec)Backwards (hex)Backwards (dec)
0x053
0x000
830x0C0
0x0FF
65472
0x06C
0x000
1080x08C
0x0FF
65420
0x013
0x001
2750x065
0x0FE
65125
0x0A8
0x002
6800x061
0x0FD
64865
0x07E
0x005
14080x04C
0x0FB
64332
0x069
0x00F
39450x030
0x0F8
63536
0x07B
0x016
57550x0F0
0x0E0
57584
As we can see, when moving forwards the values go from 0 to over 5k, while going backwards the values would go from 65535 to about 57k.
Armed with this knowledge, we can easily map the input of a potentiometer to the range of speed desired, and control the motor from our favorite dev board!
[deleted]
Alvaro Ferrán Cifuentes wrote 09/18/2016 at 09:17 point
Well to be honest I didn't realize it, but that makes a lot of sense actually.
