WS2812 led rings, Pi zero mini, finish light strips for shelves
A project log for Hardware Hacking Twitch stream
Hardware hacking twitch.tv stream where I work on projects and maybe play some games every once in a while
I looked at the local copy, and the window was super small. Also I need to work on speaking loudly enough. The microphone is on the camera, attached to the monitor. Maybe I'll put a towel under the monitor to try and deaden vibrations..? Anyway, thanks for the feedback, it helps make things better!
It seems like the mic is on your desk and that everything that is happening on it is louder than you are speaking :( and now everything is black. I'm trying to watch the recorded session later :)
