Live in ten... or so
A project log for Hardware Hacking Twitch stream
Hardware hacking twitch.tv stream where I work on projects and maybe play some games every once in a while
j0z0r-pwn4tr0nj0z0r pwn4tr0n 09/04/2016 at 17:002 Comments
WS2812 led rings, Pi zero mini, finish light strips for shelves
j0z0r pwn4tr0n wrote 09/05/2016 at 04:02 point
I looked at the local copy, and the window was super small. Also I need to work on speaking loudly enough. The microphone is on the camera, attached to the monitor. Maybe I'll put a towel under the monitor to try and deaden vibrations..? Anyway, thanks for the feedback, it helps make things better!
davedarko wrote 09/04/2016 at 18:32 point
It seems like the mic is on your desk and that everything that is happening on it is louder than you are speaking :( and now everything is black. I'm trying to watch the recorded session later :)
