I have launched a Kickstarter campaign to bring a Raspberry Pi Tough case to the users. The case houses a 7 inch display and all USB, GPIO, Analog audio out, Micro SD and Ethernet can be accessed from the case top. All brackets are 3D printed with ABS and all the facades are made from 3mm laser cut acrylic. The case is both Pi 2 and Pi 3 compatible and is named the Tough Pi. There are varying rewards from a bare prototyping case just fit your Pi and provide power, to a complete solution with power supply and mini keyboard. Please check it out and post any feedback, I'm happy to answer questions.
<a href="https://www.kickstarter.com/projects/957732914/tough-pi?ref=user_menu" target="_blank">https://www.kickstarter.com/projects/957732914/tough-pi?ref=user_menu</a>
please add router and completly offgrid (solar panels?) and 365 days working with wifi or ethernet.
In my opinion box faraday is better than only abs
and add outernet connect ;-) many people need outernet connections but no have idea what using this
