How to create an app for Arduino projects
Making an Android application for Arduino hardware
This project is about making an Android application for a WiFi connected Huzzah ESP8266. Learn how to create an Android app with a Huzzah ESP8266 running the Arduino IDE. Check out the basic setup of the Huzzah and Blynk app in this project https://hackaday.io/project/8831-huzzah-esp8266-and-blynkcc-app Follow this project to stay updated while I document the steps covering the idea to the finished product.
Where is everything? This project has just started!
To do:
  • Android app setup and bootstrapping
  • Writing and testing the Android app
  • Publishing the app
There will be published logs covering the above and more. Follow this project above for updates.
  • 1 × Arduino compatible board
  • 1 × Android smartphone
  • Connect the Arduino hardware to the local app server
    Richard Hogben09/26/2016 at 19:41 0 comments
    To check that everything is working locally in a standard configuration I update the Arduino sketch and connect to the locally running app server.
    Startup the local server
    From the location of the java server start the server from a terminal and verify the server is running.
    In terminal run:
    java -jar server-0.18.2-SNAPSHOT.jar
    In browser ( remember https in the url):
    https://YOUR_LOCAL_IP:7443/admin
    Login to the Blynk app locally and add a new Blynk project
    From the login screen click on create new account. This is separate from the Blynk servers so the email and password can be whatever you want.
    Click on the stoplight looking settings icon and switch to custom, then enter your local server IP.
    When login is complete check that your new user displays on the local server.
    Create another hello world led toggle project in the Blynk app. Note the Auth ID, email won't work but you can tap it to copy and email it to yourself manually
    Update the Arduino sketch and upload
    The new sketch has an IP address value added in Blynk.begin, this should be the IP of your local Blynk server. Enter you new Auth ID from above. Update this sketch, re verify, and upload, if you need help refer to the ESP8266 and Blynk setup steps.
     * Blynk is a platform with iOS and Android apps to control
     * Arduino, Raspberry Pi and the likes over the Internet.
     * You can easily build graphic interfaces for all your
     * projects by simply dragging and dropping widgets.
     *   Downloads, docs, tutorials: http://www.blynk.cc
     *   Blynk community:            http://community.blynk.cc
     *   Social networks:            http://www.fb.com/blynkapp
     *                               http://twitter.com/blynk_app
     * Blynk library is licensed under MIT license
     * This example code is in public domain.
     * This example runs directly on ESP8266 chip.
     * You need to install this for ESP8266 development:
     *   https://github.com/esp8266/Arduino
     * Please be sure to select the right ESP8266 module
     * in the Tools -> Board menu!
     * Change WiFi ssid, pass, and Blynk auth token to run :)
    #define BLYNK_PRINT Serial    // Comment this out to disable prints and save space
    #include
    #include
    // You should get Auth Token in the Blynk App.
    // Go to the Project Settings (nut icon).
    char auth[] = "XXXXXXXXXXXXXXXXXXXXXXXX";
    // Your WiFi credentials.
    // Set password to "" for open networks.
    char ssid[] = "XXXXXX";
    char pass[] = "XXXXXX";
    void setup()
      Serial.begin(115200);
      Blynk.begin(auth, ssid, pass, IPAddress(XXX,XXX,XX,XX));
    void loop()
      Blynk.run();
    Refresh the server page and navigate to Hardware boards to check that the device has logged in locally.
    From the Blynk app run your app and toggle the button, the LED should turn on and off if you used the blink led example linked above. This is all that's needed to test the local server and Arduino hardware. If it works everything is ready for creating a custom Android app.
  • Running the local app server for the project
    Richard Hogben09/14/2016 at 20:41 0 comments
    The local Blynk server requires a few steps to get running. When complete, you will have access to the admin panel for the local app server ready to take connections from the Android app and the Arduino hardware.
  • Android app project idea, turntable tonearm lifter
    Richard Hogben09/06/2016 at 19:34 2 comments
    To decide on an idea I first looked for a problem I could solve or a problem that has been solved before but could be improved on.
    Turntables
    When I listen to records at home I run across two issues. I'm sometimes not in the same room when the record is finished and the needle is left on the record. Other times I would just like to pause the record but again I'm upstairs or otherwise not in front of the turntable. These are two minor inconvenices I think could be fixed.
  • Ideas for creating an app for Arduino projects
    Richard Hogben09/02/2016 at 01:00 0 comments
    Requirements
    What about the app?
    Will start with React Native, which requires Android Studio and JavaScript knowledge. This also means the code can be shared and run in Xcode for an iOS build.
View all 4 project logs
mikewolflamar wrote 01/18/2020 at 07:29 point
I have an application that has the latest features, technologies in the development of mobile apps from stormotion. I would say that it is at a reasonable price, you can also get an application that will be of interest to users, and then you can improve your business. This is a pretty good service, https://stormotion.io/. They work for a long time and have positive feedback from customers on the application market.
