Running the local app server for the project
A project log for How to create an app for Arduino projects
Making an Android application for Arduino hardware
richard-hogbenRichard Hogben 09/14/2016 at 20:410 Comments
The local Blynk server requires a few steps to get running. When complete, you will have access to the admin panel for the local app server ready to take connections from the Android app and the Arduino hardware.
First make sure you have Java 8 running, in a terminal type
java -version
Download the server
server-0.18.2-SNAPSHOT.jar
Create a file 'server.properties' add these two lines and save it in the same folder as the server
admin.rootPath=/admin
allowed.administrator.ips=0.0.0.0/0
Run the server, from the terminal enter
java -jar server-0.18.2-SNAPSHOT.jar
Open a browser to
https://YOUR_LOCAL_IP:7443/admin
Ignore any ssl warnings in the browser and proceed. You should see the server dashboard.
