Double joint
A project log for Custom Articulated Joint
I'm building a robot which requires small, articulated joints. Unfortunately I couldn't buy any, so I made my own.
tim-wilkinsonTim Wilkinson 09/18/2016 at 00:392 Comments
Here's a quick photo and video of two joints connected together - mostly a test that one can life the weight of the other, and that the software network actually works as intended.
Video:
Tim Wilkinson wrote 09/19/2016 at 04:31 point
That's something I'm thinking about too, but so far haven't had the chance to put any time into.
deʃhipu wrote 09/18/2016 at 08:27 point
Looking at it, I wonder if it would be feasible to make a ball joint, with each axis being controlled by a motor on each side of it.
