PSU Design
A project log for Proxxon Micromill CNC Conversion
Converting a cheap Proxxon Micro Mill to CNC
morganmorgan 02/19/2014 at 23:151 Comment
Added link to the PSU design I will be implementing. Basically chaining ​the two ATX power supplies I already have together to get 24v @ some beefy amps. I read before I should be able to get upwards to 21A but cannot find that resource.
Robotech wrote 07/22/2014 at 20:13 point
your ATX already give you 24 volts with your -12 and + 12
