API on SatNOGS Network
A project log for SatNOGS - Global Network of Ground Stations
SatNOGS is an open source ground station and network, optimized for modularity, built using affordable tools and resources.
Pierros PapadeasPierros Papadeas 10/25/2014 at 21:220 Comments
The SatNOGS Network website has had the focus in terms of development from our software team in the past week. While the major functionality (observation calculation and scheduling) is coming along nicely (thanks to libraries like python-ephem) we are also delivering other needed functionality. This time it was a public, well documented, open API.
Based on Django REST Framework, we deployed an API that matches our current DB model and enables other applications or services to query SatNOGS Network for information about Ground Stations, Observations, Data, Transponders or even Satellites.
You can check the code in our repo , or play around with it in our dev instance.
For now authenticated users of the website are the only ones with POST (write) access, anyone else can view only (GET). We are planning API-key based access so that Stations can submit recorded Data once they are done with their scheduled part of the observation.
