SatNOGS DB, the open satellite transmitter database opens for contributions
A project log for SatNOGS - Global Network of Ground Stations
SatNOGS is an open source satellite ground station network, optimized for modularity, built using affordable tools and resources.
elkoselkos 07/23/2015 at 00:550 Comments
Early on, while developing SatNOGS, the SatNOGS team encountered the lack of a central and editable database for active satellite transmitters. Such information would be vital not only for SatNOGS operations but also for amateur radio operators interested in satellite telecommunications.
Over the past many years, lots of radio amateurs undertook the challenge by creating personal pages that would keep track of transmitter data, and although there are really fine examples of such efforts (props to PE0SAT, JE9PEL, OZ9AEC, AMSAT-UK and others) those are unfortunately not scalable approaches, that could easily become deprecated and are not easily exported for further usage.
Our solution was to create SatNOGS DB an open satellite transmitter database, that allows everyone to suggest transmitter information of active satellites and collaborate in keeping the database up-to date. SatNOGS DB information is freely and openly (CC-BY-SA) accessible via an API and a web application, to facilitate the needs of satellite radio operators across the globe.
satnogs-db
Technically our current implementation is based on the Django Python framework. The code can be found here and we are looking for code contributors as always! Do you have any suggestions on how we can make SatNOGS DB better? File away issues here, so we can make DB better for everyone.
If you are a satellite operator, or an amateur radio enthusiast and would like to make suggestions on populating SatNOGS DB don’t hesitate to check out our FAQ on how to do so.
satnogs db
The more transmitter information we have, the easier it is to communicate with many more satellites. So get those contributions started, and together let’s create the holistic, open and crowd-sourced satellite transmitter database once and for all!
(cross posted in the SatNOGS blog)
