What AT Can Help Students with Disabilities?
A project log for LipSync
An assistive tech which allows quadriplegics to use touchscreen mobile devices using a mouth-operated joystick with sip and puff controls
makers-making-changeMakers Making Change 07/19/2018 at 17:451 Comment
We are currently working on expanding our open-source assistive technology library by adding devices that can help youth. We have some questions for teachers to help us get started.
A hand using a key turner to open a door
The key turner, a popular low-tech AT device from our library
What disabilities do your students have? Are there any assistive devices you can think of that would be a valuable addition to your classroom? If your students are already working with some assistive technology, click a photo of the device and send it to us!
You can reach out by contacting Zee Kesler, Makers Making Change Project Manager, at zeek@neilsquire.ca. Thank you for your help!
Marie Brito wrote 03/03/2020 at 14:04 point
This is very good software for the photo editing and organizing your albums. You can see that this has the simple interface ad simple use which I can easily check https://do-my-assignment.com/do-my-homework-australia to get best homework. This can be use for the beginners to learn how to use the high level applications to use different software.
