Building LipSyncs with Neil Squire Solutions
A project log for LipSync
An assistive tech which allows quadriplegics to use touchscreen mobile devices using a mouth-operated joystick with sip and puff controls
makers-making-changeMakers Making Change 02/15/2018 at 19:340 Comments
In late January, the Neil Squire Solutions team worked with us to build some LipSyncs. Many of them were soldering for the first time, but they successfully built seven devices together. Check out some photos here.
If you're new to making, you may shy away from taking on a project like the LipSync. To prove that it shouldn't be intimidating at all, we put together this time-lapse of one of the Solutions team members building a device. Click the image below to open the video in a new window:
Two hands working on LipSync parts
On February 3rd, Piriya and Gemma from the Solutions team were at the ATIA Maker Day in Orlando. They saw several interesting projects and learned a lot:
3D-printed tilt-compensating wheelchair cup holder
Above: A 3D-printed tilt-compensating wheelchair cup holder
Piriya learning to build an inexpensive phone stand made of corrugated plastic
Above: Piriya learning to build an inexpensive phone stand made of corrugated plastic
For more coverage, check out this article from ATMakers.org, the hosts of the ATIA Maker Day.
