Protocol Ideas
A project log for Push to Reboot
Telecommand power management using handheld radios
Blaine MurphyBlaine Murphy 04/15/2018 at 18:020 Comments
In the last log I started to define a simple protocol that fits in a 5 character DTMF PTT-ID. I have since thought of some additions that would make the protocol more useful and secure. I'm using this log to capture some of these ideas and open them for discussion/suggestion.
Each node has an ID number assigned to it. This ID was defined as zero-indexed in the last log, but I think it would be more intuitive to reserve ID 0 for a special case and start node and port numbering at 1. One-indexed addressing would mean node 1 and port 1 would have address 1 instead of 0 which (to me) feels more natural when using a numerical keypad. The use of 0 would then be to multicast a command to all nodes or an action to all ports. For example, the command *00A# would now perform action A on all ports of all nodes. To addess the first port of the first node (as in the last log) the command would be *11A#.
I've mentioned "actions" for ports, but until now I haven't defined any. Actions are assigned to the DTMF letter digits A, B, C, and D. The commands containing these actions will most likely be programmed as PTT-IDs, but theres a chance at some point they will be keyed in manually. I have assigned verbs to each action to make programming and manual keying easier.
ActionVerbDescription
A
ActivateTurn the port(s) on.
B(re)BootTurn the port(s) off for 5 seconds, then on.
CCallTurn the port(s) on for 5 seconds, then off.
DDeactivateTurn the port(s) off.
After expanding the capabilities of the controller to deactivate all devices on multiple nodes I started to worry a bit about security. The ability to multicast is very useful and very dangerous. Without safeguards in place any radio owner is able to control the power of any device they can find. This is obviously no good, so some form of authentication must be used.
After looking around for existing telecommand authentication methods I found a very interesting video about telecommand using authenticated APRS messages. The method described is a form of time-based one-time password (TOTP) algorithm. The general idea is to send a token from sender to receiver that verifies the identity the sender. A secret like a password is held secretly by both the sender and receiver. This secret is salted with the current timestamp and hashed to create a token which is then sent from the sender to the receiver. When the receiver receives the token it generates a new token using the same process and compares the two. These two tokens will only match if the secret and timestamp matches on both ends. The token is time-sensitive and secret-based meaning the secret must be known to create it and it cannot be reused after a short period of time by a third party.
I really like the method described in the talk by K7UDR because it's a standard that is currently in use. There is, however, one small problem with the proposed method. Both the sender and receiver must have accurate and synchronized time sources. This means the use of a real time clock and/or the use of network time synchronization. I would like to avoid the extra complexity and additional hardware that would be necessary when using time-based token generation. After searching a bit more I found another algorithm that generates something called an HMAC-based one-time password (HOTP). Like a TOTP, an HOTP is generated using a changing salt to prevent replay attacks, but unlike a TOTP an HOTP doesn't require a time source to be generated. An HOTP is generated using a counter that is incremented by both sender and receiver after every successful authentication. I think this is a good compromise for the application because it allows some security without increasing the cost of each node being built.
I wanted to get these ideas out and written down before working on any software or hardware. I think this protocol will be convenient and secure, but there are probably a lot of issues I haven't thought of. The DTMF boards have arrived from Amazon so I get started on a basic firmware while I think of more protocol ideas.
