Step 3 video (testing MQTT, configuring openHAB, calibrating sensor)
A project log for Kube Multi Sensor Platform
This is more than just a temperature/humidity sensor with an OLED screen - it is a multi-sensor platform for all your ha sensor needs!
b-kB K 04/22/2018 at 14:570 Comments
Just released the third step video for building the sensor. In this video, I focus on showing how to test the MQTT output from the sensor, how to configure openHAB to receive the sensor data and graph it, and how to calibrate the sensor to existing thermostat sensors. After this, the sensor is fully connected to the home automation system for monitoring/charting.
