New Design Completed
A project log for CNC Laser PCB Maker
X carve Inspired Laser CNC machine which can help Develop quality PCB at home without using expensive photography films and dusty milling.
manjuprasadmbasangimanjuprasadmbasangi 09/08/2016 at 15:467 Comments
2. 8-9-2016 New Design Completed. will get all the parts Manufactured by next week.
Simon Merrett wrote 09/14/2016 at 07:50 point
It was ebay item number 161130761148 but if you are struggling, a re-focussed 405nm laser pointer is pretty similar and that's what I started with.
manjuprasadmbasangi wrote 09/14/2016 at 07:54 point
ok you buy from ebay, good i am thinking of using optics for focusing laser to 0.025mm dot and i may need your help
Simon Merrett wrote 09/14/2016 at 08:00 point
Let me know - I'm pretty inexperienced in anything of that precision but will try
Simon Merrett wrote 09/10/2016 at 19:58 point
 I am making something similar based on this http://www.g3gg0.de/wordpress/uncategorized/um2-laser-addon-part-2/
But with a corexy grbl. I used a much less powerful laser (few mW 405nm laser pointer) and managed to draw the circuit trace outline on heat sensitive receipt paper. I'm going to try photosensitive pcb film next and have a 20mW laser in the mail from China.
manjuprasadmbasangi wrote 09/14/2016 at 05:10 point
Hi, sorry for late reply, i have already tried this and thanks for the link to machine , when will you get the 20mW laser, i have got myself 100mw & 1W laser and i wanted to use semitransparent object to reduce its strength and try again. i am facing the light bleeding from the laser i.e some light bleeds to region surrounding the laser dot this is causing the photo resist to dry out due to this light.
Any idea how can i stop that?
Simon Merrett wrote 09/14/2016 at 06:53 point
I haven't tried with photoresist yet, still taking the chance to transfer the mechanism to its own frame.  20mW laser is here though.
manjuprasadmbasangi wrote 09/14/2016 at 07:33 point
Can you please post photos of the laser module and where did you get the laser from(website) like banggood etc
