Machine assembled
A project log for CNC Laser PCB Maker
X carve Inspired Laser CNC machine which can help Develop quality PCB at home without using expensive photography films and dusty milling.
manjuprasadmbasangimanjuprasadmbasangi 09/22/2016 at 15:170 Comments
New Frame design manufactured and assembled (looks a lot like Chinese). Complete aluminium and MS no acrylic or plastic parts
After Using PLanet CNC
i used HPGL files for engraving the pcb using laser.
This is after exposing laser on photo resist
As you can see, a bit of plastic from the dry flim is melted and cannon be removed (due to high power) and light Bleeding
Even though the engraving on wood is as below
