​3) OLED Break Out Module
A project log for Pi-Fi Drouter
A Raspberry PiZero based mobile router with wireless storage and memory expansion capability
fadilluqumanfadilluquman 11/18/2016 at 11:080 Comments
When it comes to mass production, it's best fit to design the whole board with discrete components rather than buying individual components, assembling and integrating them. It simply adds to the cost as well as space. Under Adafruit's courtesy, I have made a few changes with some components and added some design notes. The OLED module is pretty straight forward apart from the bidirectional logic level shifter. You can find more information about it in the following pdf: http://www.nxp.com/documents/application_note/AN10441.pdf
Refer the following schematic for the same:
