Powder and Dispenser
A project log for Upcycled Full Color 3D Printer
3D color printer from household scraps
jlamJLAM 01/04/2015 at 22:110 Comments
Powder tried:
PowderResult
Plaster + Talcum powderNot enough strength both immediately after print and after setting
Plaster + sugar + dextrin
Increase wet strength, but very difficult to spread. Also very messy.
Salt + dextrinGood wet strength, improved with baking. Easy to spread.
The final powder is made by baking table salt to dry. Then ground to fine powder with coffee grinder. The powder is mixed at 8:1 with Malt dextrin.
For the dispenser the first simple design was a simple sheet metal bent into a box. Below is a picture to explain it.
It is a completely passive system as the sweeper bar is moving. The further back the bar moves, the more powder it will pickup.
This dispenser place strain on the sweeper bar and hence does not fit into current design.
