More Temperature Testing
A project log for Solid-state garduino with RTC & LCD!
Garduino Enclosure with Solid State Controlled Relays, Real Time Clock, and status LCD.
vwphanvwphan 02/20/2014 at 14:260 Comments
After 4 Hours with only the light on the chamber hit ~29C.  This is ok cause the target temperature range is 22-25C.
Performing a second test that uses the same code, but electrifies the heating pad, without the lamp.
My hunch is that with the lights on, I'll not need to also have the heating pad on to maintain a good temperature range.​
