Upgraded LED Parts coming overnight
A project log for Invisible QR Code Navigation for Robots 2020
Cheap UV invisible QR codes for indoor navigation of robotics. Print labels from Inkjet Printer and read with a normal camera.
josh-starnesJosh Starnes 10/10/2018 at 19:380 Comments
UV 3 watt leds and IR 3 watt leds are on the way as well as heat sinks to solder them too. I plan to use compass error correction for the heading between QR codes. I already have regular 5mm leds , but I need something a little bigger for ceiling reading clearly.
In addition to the LEDS, I ordered a compass module because I cannot locate the one I ordered for the project.
