Building the custom led illumination 850nm
A project log for Invisible QR Code Navigation for Robots 2020
Cheap UV invisible QR codes for indoor navigation of robotics. Print labels from Inkjet Printer and read with a normal camera.
josh-starnesJosh Starnes 04/14/2018 at 13:000 Comments
This last pic shows the inside of the lens where I popped the filter out. Honestly the camera is much more sensitive in low light without the filter and doesn't significantly effect the picture quality as far as color. But clarity in low light , wow! I popped it out with the tip of a xacto knife and if you kept it could easily be popped back in at any time.
