Paper ink drop comparing inks
A project log for Invisible QR Code Navigation for Robots 2020
Cheap UV invisible QR codes for indoor navigation of robotics. Print labels from Inkjet Printer and read with a normal camera.
josh-starnesJosh Starnes 07/08/2018 at 02:220 Comments
ok so the UV inks I ordered made for a inner cartridge came in. I am slightly disappointed because the red is practically non existent. Anywho I compared them to noodlers ghost bullet proof inks and the white and green inkjet inks were much brighter. As I mentioned before I am considering using both IR and UV for maximum contrast in any lighting conditions or lack there of.
All are normally invisible without special lighting , filters or camera.
Top - not visible is magenta
2nd- white UV
3rd- blue UV
4th -green UV
5th-  Noodlers Ghost UV
Tests against white paper is neeto,but the goal is to make invisible markers so I will print onto Matt or clear plastic. I put some on my finger of the green as well as the noodlers ghost white, the green is a tiny bit brighter. It is so close!!
Next is to start filling ink cartridges
