Making the Rovio Thicker
A project log for Invisible QR Code Navigation for Robots 2020
Cheap UV invisible QR codes for indoor navigation of robotics. Print labels from Inkjet Printer and read with a normal camera.
josh-starnesJosh Starnes 10/08/2018 at 22:200 Comments
HUpdate, inside the Rovio is very tight so I am modding the body to accept a spacer 1.5 inches thick to make room for modern electronics. Laminated mdf carved until the top fits smoothly in. once it is sealed and texture sprayed black it will look like it was built that way! Stay tuned
