Building space in the Rovio
A project log for Invisible QR Code Navigation for Robots 2020
Cheap UV invisible QR codes for indoor navigation of robotics. Print labels from Inkjet Printer and read with a normal camera.
josh-starnesJosh Starnes 10/09/2018 at 01:320 Comments
the Rovio is very tight inside , but fortunately I found a clever way to triple the internal space for the added equipment. I used thin sheets of mdf , glued and clamped them together to get the desired thickness. I traced the body of the Rovio onto the wood blank and cut to shape with a band saw.
