Version 2 testing QR on ceiling
A project log for Invisible QR Code Navigation for Robots 2020
Cheap UV invisible QR codes for indoor navigation of robotics. Print labels from Inkjet Printer and read with a normal camera.
josh-starnesJosh Starnes 10/25/2018 at 02:250 Comments
Here is the QR code printed on paper in normal lighting of my home,  the ink is completely invisible until it is hit with the UV and IR lighting.
This is a normally lit room but the violet shows so bright through the camera that the brightness auto adjust darkens the surrounding area. The QR is certainly readable with this newer light source.
