DCF77 signal reception video added - must see!
A project log for "Connect" to an atomic clock in space! GPS, DCF77
This project is a clock with radio receivers which can receive the exact time from the GPS satellites or from the DCF77 transmitter.
hkdcsfhkdcsf 07/07/2014 at 22:460 Comments
On the video below You can see on the oscilloscope how the DCF77 signal waveform looks like. You can also see how the two separate clocks are snychronizing to the DCF77 signal.
