One of the greatest functions ever written is the rotation matrix calculator or affine transformation. Pass it a direction vector for the Y axis to point in. It's hard coded for the Z axis to point up. Then, merely multiplying the rotation matrix by any coordinate makes the coordinate relative to the direction vector. All those highschool trig calculations & polar conversions are reduced to a matrix multiplication.
python code:
def vecToRot(direction): direction = direction.normalized() up = Vector([0, 0, 1]) xaxis = up.cross(direction) xaxis = xaxis.normalized() yaxis = direction.cross(xaxis) yaxis = yaxis.normalized() result = Matrix(( (xaxis.x, yaxis.x, direction.x), (xaxis.y, yaxis.y, direction.y), (xaxis.z, yaxis.z, direction.z))) return result usage to rotate an x,y,z coordinate 45 deg: mat_rot = vecToRot(Vector([1, 1, 0])) rotated_coord = mat_rot * Vector(x, y, z)
