Engineering Sketches of Desired Actuation Method
A project log for BEOWULF
Robotic Exoskeleton for Grip Enhancement and Stroke Rehabilitation
chad-paikChad Paik 09/12/2016 at 14:290 Comments
We were initially attempting to control 2 fingers at a time with one actuator alongside a 4-bar linkage actuation design. We also brainstormed a good joint design that's ergonomic for the user to move their finger in (we later realize that we failed at this intention). We ended up deciding that we were going to use the Myo (not MIO) armband for the EMG signal processing for ease of use and then later on adapt electrodes for signal processing.
Below demonstrates an example of the engineering sketch that we chose as our final actuation path we chose to take.
