• Type your title
    ActualDragon04/17/2018 at 13:20 0 comments
    There's not really much to put here, mainly because it's so simple. Literally ryan's build, with a SRF04 hot glued on the front, wired up to the nano. It's just the code that's going to be a bitch. I haven't tried turning it, only going forwards and backwards, so that'll be fun.
    I'm pretty proud of this one- I was ONE jumper wire short. i needed a female to male one, but i couldn't find it, so i soldered a wire to the end of a single female header, and covered it with heat shrink.
    One more thing, i have a newfound hate for those cheap little servos. I think i've had to replace two, just because the gears wear down or something. Maybe i should cnc some metal ones...
    I suck at coding, so thanks to this project: #Bracelet Dodges Obstacles, i'll be using that to base my code off of:
    #define echo 8
    #define trig 7
    long duration,distance;
    void setup() {
      Serial.begin(9600);
      pinMode(echo,INPUT);
      pinMode(trig,OUTPUT);
      pinMode(5,OUTPUT);
    void loop() {
    digitalWrite(trig,LOW);
    delayMicroseconds(2);
    digitalWrite(trig,HIGH);
    delayMicroseconds(10);
    duration=pulseIn(echo,HIGH);
    distance=(duration/(2*29));
    if(distance>=500 || distance<=0){
      Serial.println("____");
    else{
      Serial.print(distance);
      Serial.println("cm.");
      digitalWrite(5,LOW);
    if(distance<=45 && distance>=1){// distance in which the bracelet vibrates, you can edit according to your need
      digitalWrite(5,HIGH);
      Serial.println("Alarm!!!");
    delay(400);
